Display status of shutter in QuadClient
grochenel
Bericht door grochenel »
Hello all,
Sorry to write in English but I am French.
I start with a Gira Home Server 4 and for moment I work with QuadClient.
Regarding the shutter function, when I press the arrows (red circle on photo ) my shutter is activated and when it stops I do not have my return status displayed (red square on photo)
I have indicated my address groups for short press, long press, and position (see photo)
Where do we put address group for position status ?
Thanks in advance
Re: Display status of shutter in QuadClient
Hello TP,
You need to link this in 'Communication Objects'
you can add a listen-groupadress to another groupadres.
see picture
listening adress.png (15.75 KiB) 11327 keer bekeken
grochenel
Hi Dré,
Hi Dré,
i've try your solution and and it works perfectly.
Thank you
Remember that this also applies to the dimmers within Quad Client.
They will also just have a switching and dimming object to connect, both will require the same step as posted by Dré
